GIANT Stormguard E+1 Elektromos Trekking/cross 25 km/h Giant SyncDrive 700 + Wh használt ELADÓ
1 600 000 Ft
GIANT
Stormguard E+1
Eladóvá vált Giant Stormguard E+1 kerékpárom.
  • Giant SyncDrive Pro2 85Nm, powered by Yamaha, PedalPlus 6-Sensor technology
  • Kezelő: Giant RideControl Ergo 2 remote, Smart Assist automatic mode, 5 manual support levels, USB-C (10W)
  • Kijelző: Giant RideDash EVO, high-angle visibility, 3" full color LCD display, on-board navigation Giant RideDash EVO, high-angle visibility, 3" full color LCD
  • Akkumulátor: Giant EnergyPak 800Wh, 22700 Lithium cell technology, Aluminium casing with highest safety standard (EN50604), CO2 Neutral production
  • Töltő: Giant EnergyPak 6A smart charger, 60% in 3:00h
  • Kapcsolódás: Giant RideControl App enabled ANT+ wireless display signal with e-bike profile
  • Méretek: S, M, L, XL
  • Szín: Hematite
  • Váz: ALUXX SL aluminum, 100mm Stable Link Suspension System, Overdrive 3, 1.8" - 1.5" head tube, w/ Integrated KSA18 kickstand mount, Giant EnergyPak Plus range extender included
  • Villa: Fox AWL,1.5" tapered steerer, 100mm travel, RAIL damper, Boost 110x15QR, ESUV-optimized
  • Rugóstag: Fox Float DPS, 165x38mm, trunnion, custom tuned
  • Kormány: Giant Contour Comfort Riser 31.8x720mm
  • Markolat: Giant Connect Ego Max Plus
  • Kormányszár: Giant Contour EVO display integrated stem (S/M: 80mm, L/XL: 100mm)
  • Nyeregcső: Giant Contact Switch, dropper, 30,9mm (S:100m/ M:125mm/ L:150mm/ XL:170mm)
  • Nyereg: Selle Royal Vivo Ergo GTS
  • Pedálok: Aluminum Platform
  • Váltókarok: Enviolo Automatiq Pure Controller
  • Első váltó: -
  • Hátsó váltó: -
  • Fékek: Shimano Deore BR-M6120, 4-piston, hydraulic disc, 203mm
  • Fékkarok: Shimano Deore
  • Fogaskoszorú: Gates 24T
  • Lánc: Gates CDX carbon 130T
  • Hajtómű: Gates CDX 46T Praxis e-Cadet crankarm set
  • Középcsapágy: N/A
  • Felnik: Giant AM 27.5, Tubeless ready, 30mm inner width, e-bike optimized
  • Agyak: Giant eTracker Boost, 6-bolt, 110x15 e-bike optimized [F] Enviolo Heavy Duty autoshift [R]
  • Küllők: Sapim Strong [R] Race [F], e-bike optimized
  • Külsők: Maxxis Rekon 27.5x2.6", 60TPI Foldable TLR EXO
  • Kiegészítők: KSA18 direct mount kickstand, Tubeless kit (liquid, valves, levers, manual, tool)
  • Világítás: Supernova M99 Mini Pro front LED Supernova E3 Tail Light - fender integrated
  • Lakat: ABUS Xplus battery lock
  • Csomagtartó: Suspended carrier system rear. MIK system
Giant SyncDrive
1000 W
700 + Wh
80-100 mm
szíjhajtás
  • 707 megtekintés
