BERGAMONT E-CONTRAIL 8.0 Plus Elektromos Mountain Bike 27.5"+ össztelós / fully Bosch Shimano Deore XT használt ELADÓ
450 000 Ft
BERGAMONT
E-CONTRAIL 8.0 Plus
Eladó Bergamont E-Contrail 8.0 Plus (2017) – Bosch CX motoros e-bike
Kihasználatlanság miatt eladóvá vált 2017-es Bergamont E-Contrail 8.0 Plus elektromos hegyikerékpárom.
Műszaki adatok:
Frame 27.5" PLUS E-MTB, 6066 alloy super lite tubing, T4/T6 heat treated, double butted, tapered headtube, internal cable routing, 3D-dropout, travel: 120 mm
E.Drive System Motor: Bosch Drive Unit Performance CX Line, 250W, 36V, max. 25 km/h
Battery: Bosch 36 V Li Ion, 500 Wh, frame-type
Range: 500Wh: 40-215km, depending on assistance mode and riding conditions
Assistance Modes: Eco (+50%), Tour (+120%), Sport (+210%), Turbo (+300%), Walk Assist (-5km/h)
Fork Fox 34 Float, 27.5" PLUS, 120 mm, Air, 3-position micro adjust, tapered, 15x110 mm
Rear Shock Fox Float DPS Performance Series, air, Dual Piston System, EVOL, length x stroke: 190x51 mm, hardware: 22x8 mm
Headset FSA NO.57SC-1, A-Headset, semi integrated, ZS44/28.6/H8 | ZS56/40 (tapered)
Rear Derailleur Shimano Deore XT, RD-M8000, GS, Shadow Plus
Shifters Shimano SLX, SL-M7000, 1x11-speed, rapidfire plus-shifter
Brake Levers Magura MT4, hydraulic disc brake
Brakes Magura MT4, hydraulic disc brake, Storm HC rotor: 180/180 mm
Crankset BGM Delta Pro, with alloy cover, length: 170 mm
Chainguide BGM pulley with chain guide
BB-Set Bosch, ISIS
Handlebar BGM Pro, riser bar, backsweep: 9°, rise: 10 mm, width: 740 mm
H'stem Answer AME, 6°, length: 70 for S, clamp diameter: 31.8 mm
Pedals Wellgo C128
Seatpost Manitou Jack, dropper post, 31.6 mm, length: 450 mm, 125 mm travel, remote
Seat SDG Falcon RL
Hub (Front) Sun Ringle Expert AL, 6-bolt, disc, 15 mm axle
Hub (Rear) Sun Ringle Expert AL, disc, 6-bolt, 12x148 mm
Chain KMC X11E, 11-speed, for Bosch E-bike
Cassette Shimano SLX, CS-M7000, 11-speed, 11-42t
Spokes stainless, black
Rims Sun Ringle Duroc 40 Expert AL wheelset, disc, 6-bolt
Tires Front: Schwalbe Nobby Nic, SnakeSkin, TL-Easy, 70-584 TSC
Rear: Nobby Nic, SnakeSkin, TL-Easy, 70-584 PSC
Tubes: Schwalbe SV21F, 54/75-584
Approx weights in KG 22,24
Weight w/o battery: 19,74
Range of use Category 3: Cross-country, marathon and hardtail bikes
Color dark silver/yellow (matt/shiny)
Frame size S
Grips BGM Race, MTB, double density, clamp version
Gear ratio 1x11-speed, front 14t, rear: 11-42t
Állapot:
  • Megkímélt
  • Töltő és kulcsok járnak hozzá
    Az ár irányár, észszerű keretek között alkuképes. Kérésre tudok még képeket küldeni!
250 W
401-500 Wh
101-120 mm
Shimano Deore XT
27.5"+
Hely
Fejér
Térkép nagyítása
  • 739 megtekintés
