CUBE CUBE STEREO HYBRID 160 HPC SL 625 27,5 Elektromos Mountain Bike 27.5" (650b) össztelós / fully Bosch használt ELADÓ
1 000 000 Ft
+ 1db pótakkumlátor a vételár része.
Méret: 18"
ÉVJÁRAT 2021
VÁZ C:62 Monocoque Advanced Twin Mold Technology, Aluminum 6061 T6 Rear Triangle, Efficient Trail Control, FSP 4-Link, Agile Trail Geometry, Boost 148, Full Integrated Battery
VILLA RockShox ZEB Charger R, 15x110mm, Tapered, eMTB Approved, 170mm
KORMÁNYCSAPÁGY ACROS AZX-1030, Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm)
STUCNI CUBE Performance Stem E-MTB, 31.8mm
KORMÁNY Newmen Evolution SL 318.25, 760mm
MARKOLAT CUBE Race Grip 31mm, 1-Clamp
HÁTSÓ VÁLTÓ Sram NX Eagle™, 12-Speed
VÁLTÓKAROK Sram NX Eagle™ Trigger, Single Click
FÉKEK Magura MT Thirty, Front 4-Piston/Rear 4-Piston, Hydr. Disc Brake (203/203)
HAJTÓMŰ ACID E-Crank, 36T, 165mm
LÁNC Sram SX Eagle™
SZÍN grey´n´black
RUGÓSTAG RockShox Deluxe Select, 205x60mm, Rebound Adjust, Trunnion Mount
FOGASKOSZORÚ Sram PG-1210 Eagle™, 11-50T
ELSŐ AGY Shimano HB-MT400-B, 15mm, Boost, Centerlock
HÁTSÓ AGY Shimano FH-MT400-B, 12mm, Boost, Centerlock
FELNIK CUBE EX30, 32H, Disc, Tubeless Ready
HÁTSÓ GUMI Maxxis Minion DHR II, MaxxGrip/DoubleDown, Tubeless Ready, 2.4 WT
NYEREG Natural Fit Venec
NYEREGCSŐ CUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mm (S:100mm, M:125mm, L, XL:150mm)
NYEREGCSŐ BILINCS CUBE Screwlock Semi-Integrated, 34.9mm
AKKUMULÁTOR Bosch PowerTube 625
MOTOR Bosch Drive Unit Performance CX Generation 4 (85Nm) Cruise (250Watt) 25 km/h
KIJELZŐ Bosch Kiox
ELSŐ GUMI Maxxis Assegai, MaxxGrip/EXO+, Tubeless Ready, 2.5 WT
RUGÓSTAG PERSELYEZÉS Top:54mm Trunnion Mount, Bottom:22.2x8mm
TÖLTŐ Bosch 2A
LÁNCTERELŐ e*thirteen Plus e*spec
MAXIMUM RENDSZER SÚLY 135 kg
SÚLY 24,5 kg
27.5" (650b)
  • 371 megtekintés
