700 000 Ft
KELLYS
Tayen R10 P S 27.5" 725Wh Elektromos Hardtail MTB
Új, a hétvégén nyertem sorsoláson.
| Váz: KELLYS TAYEN R-series - advanced robotic welded 6-series aluminium alloy | ||||||||||
| Motor: PANASONIC GX Ultimate, 95 Nm, 36 V, 1.5" tapered HT, 12x148 mm Boost thru axle | ||||||||||
| Akkumlátor: KELLYS Re-Charge K1 Li-ion internal removable 725 Wh / capacity 20 Ah, co-developed by Kellys-BMZ | ||||||||||
| Kijelző: PANASONIC Bluetooth® 5.0 navigation Side Color Display | ||||||||||
| Villa: SR SUNTOUR XCM 32 DS (29") Boost, 120 mm, coil spring / 15 mm thru axle | ||||||||||
| Váltó: SHIMANO Altus M2000 (direct mount), Fokozatok száma: 9 | ||||||||||
| Váltókar: SHIMANO Altus SL-M2000 Rapidfire Plus | ||||||||||
| Fogaskoszorú: SHIMANO CS-HG400-9 (11-36T) | ||||||||||
| Lánc: KMC e9S | ||||||||||
| Fék: SHIMANO MT200 Hydraulic Disc | ||||||||||
| Fékkar: SHIMANO BL-MT200 | ||||||||||
| Féktárcsa: 180 mm front / 180 mm rear | ||||||||||
| Kerékagy: SHIMANO MT400-B Disc Center Lock (32 holes) | ||||||||||
| Felni: KLS Draft Disc 622x21 (32 holes) | ||||||||||
| Küllő: stainless steel black | ||||||||||
| Gumi: MITAS Ocelot 60x584 (27.5x2.35). | ||||||||||
| Kormánycsapágy: FSA 1.5 semi-integrated | ||||||||||
| Tengely rögzítés: SR SUNTOUR 15x110 mm front / NOVATEC 12x181 mm rear | ||||||||||
| Kormányszár: KLS Alm/En 50 - diam 28.6 mm / bar bore 31.8 mm / length 45 mm | ||||||||||
| Kormány: KLS Active RiseBar - diam 31.8 mm / rise 18 mm / width 700 mm | ||||||||||
| Markolat: KLS Poison OneLockon | ||||||||||
| Nyeregcső:KLS Active - diam 30.9 mm / length 350 mm | ||||||||||
| Nyereg: SELLE ROYAL Vivo | ||||||||||
Panasonic
624 W
más
700 + Wh
101-120 mm
Shimano Altus
27.5" (650b)
- 294 megtekintés
