SPECIALIZED S-WORKS LEVO SL Elektromos Mountain Bike 29" össztelós / fully Brose SRAM X01 AXS Eagle használt ELADÓ
2 990 000 Ft
SPECIALIZED
S-WORKS LEVO SL
Eladó 2021-ben a SpeedWay-ben vásárolt S-Works LEVO SL gépem.
Körülbelül 1000-1500 km van benne, szép állapotú, amennyire tudtam vigyáztam rá.
Az ár ÁFA-t tartalmaz, mely cégeknek visszaigényelhető, cégtől eladó.
Main Specs
Frame: FACT 11m full carbon fiber, Trail 29 Geometry, integrated down tube battery, Command seatpost routing, 148mm spacing, sealed cartridge bearings, 150mm of travel
Fork: Fox Float 36 Factory, Grip2 damper, 150mm, 51mm rake, HSC, LSC, HSR, LSR, Kabolt axle
Rear Shock: Fox Float DPX2 Factory, 3- position adjustment, 52.5x210mm, Rx Trail Tune
Engine: Specialized SL 1.1, custom lightweight motor
Battery: Specialized SL1-320, fully integrated, 320Wh
Groupset
Rear Derailleur: SRAM XX1 Eagle AXS
Shifters: SRAM AXS Eagle Controller
Cranks: Praxis, carbon M30, custom offset
Chainrings: SRAM X-Sync Eagle, 94 BCD, 30T
Cassette: Sram XG-1299, 12-speed, 10-52t
Front Brake: Magura MT7 with custom Loic lever blade, 203mm rotor
Rear Brake: Magura MT7 with custom Loic lever blade, 203mm rotor
Wheels
Rims: Roval Traverse SL 29, hookless carbon, 30mm inner width, 2Bliss Ready, hand-built, 28h
Tires: Butcher, GRID TRAIL casing, GRIPTON® compound, 29x2.3 / Eliminator, GRID TRAIL casing, GRIPTON® compound, 2Bliss Ready, 29x2.3
Components
Handlebar: Specialized Trail, FACT Carbon, 6-degree upsweep, 8-degree backsweep, 27mm rise, 780mm, 35mm
Saddle: Bridge, 155/143mm, Hollow Ti-rails
Seatpost: Specialized Ti-bolt-type, alloy, 38.6mm
Brose
240 W
0-400 Wh
131-150 mm
SRAM X01 AXS Eagle
  • csavaros
  • 2257 megtekintés
