1 600 000 Ft
GIANT
Stormguard E+1
Eladóvá vált Giant Stormguard E+1 kerékpárom.
- Giant SyncDrive Pro2 85Nm, powered by Yamaha, PedalPlus 6-Sensor technology
- Kezelő: Giant RideControl Ergo 2 remote, Smart Assist automatic mode, 5 manual support levels, USB-C (10W)
- Kijelző: Giant RideDash EVO, high-angle visibility, 3" full color LCD display, on-board navigation Giant RideDash EVO, high-angle visibility, 3" full color LCD
- Akkumulátor: Giant EnergyPak 800Wh, 22700 Lithium cell technology, Aluminium casing with highest safety standard (EN50604), CO2 Neutral production
- Töltő: Giant EnergyPak 6A smart charger, 60% in 3:00h
- Kapcsolódás: Giant RideControl App enabled ANT+ wireless display signal with e-bike profile
- Méretek: S, M, L, XL
- Szín: Hematite
- Váz: ALUXX SL aluminum, 100mm Stable Link Suspension System, Overdrive 3, 1.8" - 1.5" head tube, w/ Integrated KSA18 kickstand mount, Giant EnergyPak Plus range extender included
- Villa: Fox AWL,1.5" tapered steerer, 100mm travel, RAIL damper, Boost 110x15QR, ESUV-optimized
- Rugóstag: Fox Float DPS, 165x38mm, trunnion, custom tuned
- Kormány: Giant Contour Comfort Riser 31.8x720mm
- Markolat: Giant Connect Ego Max Plus
- Kormányszár: Giant Contour EVO display integrated stem (S/M: 80mm, L/XL: 100mm)
- Nyeregcső: Giant Contact Switch, dropper, 30,9mm (S:100m/ M:125mm/ L:150mm/ XL:170mm)
- Nyereg: Selle Royal Vivo Ergo GTS
- Pedálok: Aluminum Platform
- Váltókarok: Enviolo Automatiq Pure Controller
- Első váltó: -
- Hátsó váltó: -
- Fékek: Shimano Deore BR-M6120, 4-piston, hydraulic disc, 203mm
- Fékkarok: Shimano Deore
- Fogaskoszorú: Gates 24T
- Lánc: Gates CDX carbon 130T
- Hajtómű: Gates CDX 46T Praxis e-Cadet crankarm set
- Középcsapágy: N/A
- Felnik: Giant AM 27.5, Tubeless ready, 30mm inner width, e-bike optimized
- Agyak: Giant eTracker Boost, 6-bolt, 110x15 e-bike optimized [F] Enviolo Heavy Duty autoshift [R]
- Küllők: Sapim Strong [R] Race [F], e-bike optimized
- Külsők: Maxxis Rekon 27.5x2.6", 60TPI Foldable TLR EXO
- Kiegészítők: KSA18 direct mount kickstand, Tubeless kit (liquid, valves, levers, manual, tool)
- Világítás: Supernova M99 Mini Pro front LED Supernova E3 Tail Light - fender integrated
- Lakat: ABUS Xplus battery lock
- Csomagtartó: Suspended carrier system rear. MIK system
Giant SyncDrive
1000 W
700 + Wh
80-100 mm
szíjhajtás
- 1170 megtekintés
