Alig használt, kb. 280-300 km-t futott, kitűnő állapotú TREK Supercaliber 9.7 összteleszkópos karbon XC verseny 29" MTB eladó!
Tubeless kerekekkel, Race Face Chester pedállal.
Size M/L - (166-180 cm magassághoz)
Color Trek Black/Trek White
Weight 11.51 kg
Year 2020/2021
Specifications
https://www.trekbikes.com/us/en_US/bikes/mountain-bikes/cross-country-mountain-bikes/supercaliber/supercaliber-9-7/p/28588/
Frameset / Váz
Frame
OCLV Mountain Carbon main frame & stays, IsoStrut, tapered head tube, Knock Block, Control Freak internal routing, Boost148, 60mm travel
Fork
RockShox Reba RL, Solo Air spring, Motion Control damper, tapered steerer, 42mm offset, Boost110, 15mm Maxle Stealth, 100mm travel
Shock
Trek IsoStrut, Fox Performance shock, air spring, DPS 2-position damper, 235x32.5mm
Max compatible fork travel
120mm (531mm axle-to-crown)
Wheels / Kerekek
Wheel front
Bontrager Kovee Elite 23 carbon, Tubeless Ready, 6-bolt, Boost110, 15mm thru axle
Wheel rear
Bontrager Kovee Elite 23 carbon, Tubeless Ready, centerlock, Shimano 8/9/10 freehub, Boost148, 12mm thru axle
Hub front
Bontrager alloy, sealed bearing, alloy axle, 6-bolt, Boost110, 15mm thru axle
Skewer rear
Bontrager Switch thru axle, removable lever
Rim
Tire
Bontrager XR2 Team Issue, Tubeless Ready, Inner Strength sidewall, aramid bead, 120 tpi, 29x2.20''
Tire part
Bontrager TLR sealant, 6oz
Rim strip
Bontrager TLR
Max tire size
Frame: 29x2.20" Fork: See manufacturer
Drivetrain / Meghajtás
Shifter
SRAM NX Eagle, 12 speed
Rear derailleur / Hatsó volt
SRAM NX Eagle
Crank / Hajtókar
SRAM NX Eagle, DUB, 32T alloy ring, Boost (52mm chainline), 175mm length
Bottom bracket
SRAM DUB, 92mm, PressFit
Cassette / Fogaskoszorú
SRAM PG-1230 Eagle, 11-50, 12 speed
Chain / Lánc
Max chainring size / Max lánckerék méret
36T
Components / Kiegészítők
Saddle
Bontrager Montrose Comp, steel rails, 138mm width
*Seatpost
Bontrager Comp, 6061 alloy, 31.6mm, 8mm offset, 400mm length
*Handlebar
Bontrager Comp, alloy, 31.8mm, 5mm rise, 720mm width
Grips
Bontrager XR Trail Comp, nylon lock-on
*Stem
Bontrager Rhythm Comp, 31.8mm, Knock Block, 0 degree, 70mm length
*Headset
Knock Block Integrated, 62-degree radius, cartridge bearing, 1-1/8'' top, 1.5'' bottom
Brake / Fék
Shimano hydraulic disc, MT501 lever, MT500 caliper
*Brake rotor
Shimano RT56, 6-bolt, 180mm
Rotor size
Max brake rotor sizes: 180mm front, 160mm rear
Weight
M - 11.51 kg / 25.38 lbs (with TLR sealant, no tubes)
átütő (hátul)
- 1325 megtekintés
