490 000 Ft
BERGAMONT
E-CONTRAIL 8.0 Plus
Eladó Bergamont E-Contrail 8.0 Plus (2017) – Bosch CX motoros e-bike
Kihasználatlanság miatt eladóvá vált 2017-es Bergamont E-Contrail 8.0 Plus elektromos hegyikerékpárom.
Műszaki adatok:
Frame | 27.5" PLUS E-MTB, 6066 alloy super lite tubing, T4/T6 heat treated, double butted, tapered headtube, internal cable routing, 3D-dropout, travel: 120 mm |
E.Drive System | Motor: Bosch Drive Unit Performance CX Line, 250W, 36V, max. 25 km/h Battery: Bosch 36 V Li Ion, 500 Wh, frame-type Range: 500Wh: 40-215km, depending on assistance mode and riding conditions Assistance Modes: Eco (+50%), Tour (+120%), Sport (+210%), Turbo (+300%), Walk Assist (-5km/h) |
Fork | Fox 34 Float, 27.5" PLUS, 120 mm, Air, 3-position micro adjust, tapered, 15x110 mm |
Rear Shock | Fox Float DPS Performance Series, air, Dual Piston System, EVOL, length x stroke: 190x51 mm, hardware: 22x8 mm |
Headset | FSA NO.57SC-1, A-Headset, semi integrated, ZS44/28.6/H8 | ZS56/40 (tapered) |
Rear Derailleur | Shimano Deore XT, RD-M8000, GS, Shadow Plus |
Shifters | Shimano SLX, SL-M7000, 1x11-speed, rapidfire plus-shifter |
Brake Levers | Magura MT4, hydraulic disc brake |
Brakes | Magura MT4, hydraulic disc brake, Storm HC rotor: 180/180 mm |
Crankset | BGM Delta Pro, with alloy cover, length: 170 mm |
Chainguide | BGM pulley with chain guide |
BB-Set | Bosch, ISIS |
Handlebar | BGM Pro, riser bar, backsweep: 9°, rise: 10 mm, width: 740 mm |
H'stem | Answer AME, 6°, length: 70 for S, clamp diameter: 31.8 mm |
Pedals | Wellgo C128 |
Seatpost | Manitou Jack, dropper post, 31.6 mm, length: 450 mm, 125 mm travel, remote |
Seat | SDG Falcon RL |
Hub (Front) | Sun Ringle Expert AL, 6-bolt, disc, 15 mm axle |
Hub (Rear) | Sun Ringle Expert AL, disc, 6-bolt, 12x148 mm |
Chain | KMC X11E, 11-speed, for Bosch E-bike |
Cassette | Shimano SLX, CS-M7000, 11-speed, 11-42t |
Spokes | stainless, black |
Rims | Sun Ringle Duroc 40 Expert AL wheelset, disc, 6-bolt |
Tires | Front: Schwalbe Nobby Nic, SnakeSkin, TL-Easy, 70-584 TSC Rear: Nobby Nic, SnakeSkin, TL-Easy, 70-584 PSC Tubes: Schwalbe SV21F, 54/75-584 |
Approx weights in KG | 22,24 Weight w/o battery: 19,74 |
Range of use | Category 3: Cross-country, marathon and hardtail bikes |
Color | dark silver/yellow (matt/shiny) |
Frame size | S |
Grips | BGM Race, MTB, double density, clamp version |
Gear ratio | 1x11-speed, front 14t, rear: 11-42t |
✅ Állapot:
Megkímélt
Töltő és kulcsok járnak hozzá
Az ár irányár, észszerű keretek között alkuképes. Kérésre tudok még képeket küldeni!
250 W
401-500 Wh
101-120 mm
Shimano Deore XT
27.5"+
gyorszáras (elöl)
gyorszáras (hátul)
Fejér
- 418 megtekintés
