1 000 000 Ft
CUBE STEREO HYBRID 160 HPC SL 625 27,5
+ 1db pótakkumlátor és az akkumlátor szállítására is alkalmas hátizsák a vételár része.
Méret: 18"
Méret: 18"
| ÉVJÁRAT | 2021 |
| VÁZ | C:62 Monocoque Advanced Twin Mold Technology, Aluminum 6061 T6 Rear Triangle, Efficient Trail Control, FSP 4-Link, Agile Trail Geometry, Boost 148, Full Integrated Battery |
| VILLA | RockShox ZEB Charger R, 15x110mm, Tapered, eMTB Approved, 170mm |
| KORMÁNYCSAPÁGY | ACROS AZX-1030, Top Zero-Stack 1 1/2" (ZS 56mm), Bottom Zero-Stack 1 1/2" (ZS 56mm) |
| STUCNI | CUBE Performance Stem E-MTB, 31.8mm |
| KORMÁNY | Newmen Evolution SL 318.25, 760mm |
| MARKOLAT | CUBE Race Grip 31mm, 1-Clamp |
| HÁTSÓ VÁLTÓ | Sram NX Eagle™, 12-Speed |
| VÁLTÓKAROK | Sram NX Eagle™ Trigger, Single Click |
| FÉKEK | Magura MT Thirty, Front 4-Piston/Rear 4-Piston, Hydr. Disc Brake (203/203) |
| HAJTÓMŰ | ACID E-Crank, 36T, 165mm |
| LÁNC | Sram SX Eagle™ |
| SZÍN | grey´n´black |
| RUGÓSTAG | RockShox Deluxe Select, 205x60mm, Rebound Adjust, Trunnion Mount |
| FOGASKOSZORÚ | Sram PG-1210 Eagle™, 11-50T |
| ELSŐ AGY | Shimano HB-MT400-B, 15mm, Boost, Centerlock |
| HÁTSÓ AGY | Shimano FH-MT400-B, 12mm, Boost, Centerlock |
| FELNIK | CUBE EX30, 32H, Disc, Tubeless Ready |
| HÁTSÓ GUMI | Maxxis Minion DHR II, MaxxGrip/DoubleDown, Tubeless Ready, 2.4 WT |
| NYEREG | Natural Fit Venec |
| NYEREGCSŐ | CUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mm (S:100mm, M:125mm, L, XL:150mm) |
| NYEREGCSŐ BILINCS | CUBE Screwlock Semi-Integrated, 34.9mm |
| AKKUMULÁTOR | Bosch PowerTube 625 |
| MOTOR | Bosch Drive Unit Performance CX Generation 4 (85Nm) Cruise (250Watt) 25 km/h |
| KIJELZŐ | Bosch Kiox |
| ELSŐ GUMI | Maxxis Assegai, MaxxGrip/EXO+, Tubeless Ready, 2.5 WT |
| RUGÓSTAG PERSELYEZÉS | Top:54mm Trunnion Mount, Bottom:22.2x8mm |
| TÖLTŐ | Bosch 2A |
| LÁNCTERELŐ | e*thirteen Plus e*spec |
| MAXIMUM RENDSZER SÚLY | 135 kg |
| SÚLY | 24,5 kg |
27.5" (650b)
- 200 megtekintés
