1 490 000 Ft
SPECIALIZED
S-Works Epic EVO
Nagyon megkímélt, hibátlan állapotú, Fact 12 prémium karbon vázú, elöl 120, hátul 100 mm-t rugózó XC/Trail mtb. Karbon kormány, kerekek, hajtókar, fékkarok, Shimano XTR hajtómű és fékek, abszolút prémium felszereltség. Rendszeresen karbantartott, 10,40 kg súlyú kerékpár, 165-180 cm testmagassághoz való M vázméret. A Brain hátsó rugóstag frissen szervizelve, null km-es.
A felszereltsége:
FRAMESET
Frame
S-Works FACT 12m, XC Geometry, Rider-First Engineered™, threaded BB, 12x148mm rear spacing, internal cable routing, 100mm of travel
Seat Binder
Specialized Alloy, 34.9mm, Titanium bolt
DRIVETRAIN
Chainrings
Steel, 32T
Cassette
Shimano XTR M9100, 12-speed, 10-51t
Bottom Bracket
Threaded, 30mm spindle
Rear Derailleur
Shimano XTR M9100, 12-speed, Shadow Plus
Shift Levers
Chain
Shimano XTR M9100, 12-speed w/ quick link
Crankset
Race Face Next SL, 170/175mm
Rear Shock
Custom RockShox Micro Brain shock w/ Spike Valve, AUTOSAG, 51x257mm
Fork
FOX Factory Step-Cast 34, Fit4 damper, Kashima, Boost™, 44mm offset, 120mm of travel
BRAKES
Front Brake
Shimano XTR Race M-9100
Rear Brake
WHEELS
Front Tire
Ground Control, Control casing, GRIPTON® compound, 60 TPI, 2Bliss Ready, 29x2.3"
Rims
Roval Control SL, hookless carbon, 25mm internal width, tubeless-ready, hand-built
Rear Tire
Fast Trak, GRID casing, GRIPTON® compound, 60 TPI, 2Bliss Ready, 29x2.3"
Rear Hub
Roval Control SL, DT Swiss Star Ratchet, 54t engagement, DT Swiss Microspline driver body, 12mm thru-axle, 148mm spacing, 28h
Spokes
DT Swiss Competition Race
Front Hub
Roval Control SL, sealed cartridge bearings, 15mm thru-axle, 110mm spacing, 24h
COCKPIT
SeatPost
FOX Factory Transfer, Kashima, Shimano Ispec-EV lever (S: 100mm, M-XL: 125mm)
Handlebars
S-Works Carbon XC Mini Rise, 6-degree upsweep, 8-degree backsweep, 10mm rise, 760mm, 31.8mm
Stem
S-Works SL, alloy, titanium bolts, 6-degree rise
Saddle
Body Geometry S-Works Power, carbon fiber rails, carbon fiber base
Kiválóan mászik, és a 120mm-es, 34-es FOX Factory villának köszönhetően szenzációsan lejtőzik. Budapesten, a II. kerületben megtekinthető. 0620 9345220.
A felszereltsége:
FRAMESET
Frame
Seat Binder
DRIVETRAIN
Chainrings
Steel, 32T
Cassette
Bottom Bracket
Rear Derailleur
Shift Levers
Chain
Crankset
Rear Shock
Fork
BRAKES
Front Brake
Rear Brake
WHEELS
Front Tire
Rims
Rear Tire
Rear Hub
Spokes
Front Hub
COCKPIT
SeatPost
Handlebars
Stem
Saddle
- rejtett
- külső
- elektromos
101-120 mm
Shimano XTR
- átütő (elöl)
- átütő (hátul)
Budapest
- 988 megtekintés
