400 000 Ft
TREK
X-Caliber 9
2020 as trek X-Caliber MTB megkimelt allapotban elado
Tel:36-70-559-5231
Tel:36-70-559-5231
SPECIFICATIONS
Frameset
- Frame
Alpha Gold Aluminum, tapered head tube, internal derailleur & dropper post routing, rack & kickstand mount, Boost141, 5mm QR - Fork
Size: S RockShox Judy Silver, Solo Air, TurnKey remote lockout, tapered steerer, Boost110, 15mm Maxle, 100mm travel
Size: M , ML , L , XL , XXL RockShox Judy Silver, Solo Air spring, TurnKey remote lockout, tapered steerer, 42mm offset, Boost110, 15mm Maxle Lite, 100mm travel
Wheels
- Tires
Drivetrain
- Chain
Shimano SLX M7100, 12 speed - Crank
Size: S Shimano MT610, 30T steel ring, Boost, 170mm
Size: M , ML , L , XL , XXL Shimano MT610, 30T steel ring, Boost, 175mm - Bottom Bracket
Shimano SM-BB52, 73mm, threaded external bearing - Rear Derailleur
Shimano XT M8100, long cage, 51T max cog - Shifters
Components
- Brakeset
Shimano hydraulic disc, MT401 lever, MT400 caliper - Handlebar
Bontrager alloy, 31.8mm, 5mm rise, 720mm width - Saddle
Bontrager Arvada, steel rails, 138mm width - Seatpost
Size: S Bontrager alloy, 31.6mm, 12mm offset, 330mm length
Size: M Bontrager alloy, 31.6mm, 12mm offset, 360mm length - Stem
Size: S Bontrager Elite, 31.8mm, Blendr compatible, 7 degree, 60mm length
Size: M - Headset
Semi-integrated, sealed cartridge bearing, alloy cups, 1-1/8'' top, 1.5'' bottom
101-120 mm
Shimano SLX
gyorszáras (elöl)
gyorszáras (hátul)
- 2289 megtekintés
